Activity › Forums › Apple Final Cut Pro Legacy › Filler function or adjustment layer like avid/ae??
  • Filler function or adjustment layer like avid/ae??
    Posted by Coherentcut on June 11, 2006 at 1:24 pm
    Hi guys,
    I’m trying to replicate this transition effect that was done on an avid. I’m on fcp 5.1 and i have got access to boris plugins as well. Please check the link below for the video for a better idea.
    https://www.youtube.com/watch?v=H8S5ezP8Ih0
    Now on the avid i would just add edit on layer 2, drop my plugins/avx filters, render and i’m done! If i need to copy this particualr transition across few instances in my sequence, i would just need to copy the filler and duplicate it at the point where i need the transition.
    which is where i’m stuck on the fcp!! Although i managed to create the same transition on the fcp as well, i would like your thoughts on how best i can replicate this transition across the timeline.
    On the fcp I nested shot A and shot B added glow for layer 1, duplicated the same onto v2, played around with the scaling and opacity to achieve the effect. Now if i need to duplicate this transition, I would need to individually copy every plugin/scaling properties of the nested clip and paste them back again… which is a drag when you are rushing for deliveries….
    Is my method wrong? Is there a better solution?? What is the alternative on the fcp for adjustment layer in after fx??
    As i was tweaking with this, i also noticed that i can’t copy the attributes from the motion tab(basic motion, opacity etc) as a template to the browser? I’m sure i’m missing something here and would love to get some advice from you all. Thanks for your time and replies..
    cheers
    praveen KL
    Tae replied 18 years, 11 months ago 3 Members · 4 Replies
  • Kevin Monahan
    June 11, 2006 at 7:28 pm
    I can’t see your video on U-tube. Can you post it somewhere else?
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Coherentcut
    June 12, 2006 at 5:16 am
    Oops, My bad
    Just changed the video to public view. Please try again. Thanks
    cheers
    Praveen KL
  • Coherentcut
    June 13, 2006 at 5:23 pm
    Hey guys,
    I changed the access to the video. Just wondering if any of the FCP guru’s can gimme their thoughts on my post above. Thanks again.
    cheers
    Praveen KL
  • Tae
    November 2, 2007 at 2:12 pm
    I’ve been wondering the same thing. If anyone out there has any ideas, I’d love to hear them as well.
    Thanks.
