Activity Forums Adobe After Effects Fill Light Tool for Video?
  • Fill Light Tool for Video?
    Posted by Ryan Talbot on April 19, 2014 at 7:35 pm
    Hi!
    I’ve been looking all around for a plugin or effect that will brighten up the dark spots of my footage. I know this can be done in Lightroom and with RAW images through the “fill light” tool, but I want to know if there’s something out there that does the same thing to video. I’ve tried some HDR filters but those end up in the picture looking very unnatural. Are there any plugins out there for After Effects of Premiere?
    -Ryan
    Darwinius Berar replied 12 years, 4 months ago 5 Members · 5 Replies
  • Gary Milligan
    April 19, 2014 at 11:54 pm
    Premiere has “Lighting Effects”. Do a search for ‘lighting’ in the Effects.
    HTH
    Gary
  • Todd Kopriva
    April 20, 2014 at 2:41 am
    If you’re just looking to lift the shadows, try the Curves effect.
    After Effects team blog
  • Chris Wright
    April 20, 2014 at 3:40 pm
    ae’s shadow highlight filter is a lot easier to use
  • Ryan Talbot
    April 20, 2014 at 9:23 pm
    Works perfectly! Thanks!
  • Darwinius Berar
    April 22, 2014 at 12:37 am
    If you do this kind of correction is recommended to do in 32bit project because of the limited dynamic range of the video footage you can get very ugly banding effect in 8bit and even 16. Better is to set the project in 32bit and use a levels effect. Left slider is the shadows(drag to the right if you need to brighten the image), middle is the mids, right is the highlights. Just play with them until you get your look.
    Never stop learning, anything.
    Knowledge is the key to everything.
