Activity Forums Adobe Photoshop Fill Light and Recovery without Camera Raw
  • Fill Light and Recovery without Camera Raw
    Posted by Daniel Schmidt on March 2, 2008 at 5:56 pm
    I have got an image with a lot of very bright areas and very dark areas, but very low mid-tone contrast. Actually it is not an image at all, but a movie. It’s shot on video and could really use a contrast boost. Yet it is basically badly lit people in front of a white wall.
    If I were in Camera Raw, I would probably try using a lot or “Recovery” and “Fill Light” to bring the large bright (walls) and dark areas (faces) closer together and then increase the overall contrast. That way the faces would be no darker than before and the walls would be no brighter, but still the mid-tone contrast would be higher.
    Unfortunately, since this is a movie (QuickTime file) I can’t use Camera Raw. I have tried to achieve the same effect using curves, which did not work very well. Any ideas?
    Daniel
    Richard Harrington replied 18 years, 6 months ago 2 Members · 1 Reply
  • Richard Harrington
    March 6, 2008 at 1:45 am
    Use an NLE or After Effects.. they have a wealth of tools for this…
    if you must do it in CS3 Extended…
    then make it a smart object and try things like Shadow Highlights filter… as well as Exposure adjustment layers
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
