Activity Forums Adobe After Effects Expressions fill color depends on slider control
  • fill color depends on slider control
    Posted by Aqeel Arruhaili on August 15, 2012 at 2:39 pm
    Is there a way i can link a slider control values of 0,1 or 2 to a specific fill color effect of a solid layer.if the value equals 0 the color will be grey ,if it is 1 the color is green and anything else is red..How can i do that ?
    Aqeel Arruhaili replied 14 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 15, 2012 at 5:38 pm
    This should work:
    slider = Math.floor(effect("Slider Control")("Slider").value);
    if (slider == 0)
    [.5,.5,.5,1] // medium grey
    else if (slider == 1)
    [0,1,0,1] // green
    else
    [1,0,0,1] // red
    The RGBA values are represented by an array of four values between 0 and 1.
    Dan
  • Aqeel Arruhaili
    August 15, 2012 at 8:39 pm
    Thank you so much.
