Activity › Forums › Apple Final Cut Pro Legacy › files speed up to 100.15% when importing to FCP
  • files speed up to 100.15% when importing to FCP
    Posted by Trent Watts on June 20, 2012 at 9:17 pm
    Hopefully I don’t make any heads explode with this one. I’ve been editing for 10 years and this is the strangest problem I’ve ever run across.
    STRANGE PART 1
    I’m editing interviews shot on DSLR’s from two angles, and syncing them up with audio files. When I’m importing DSLR footage into FCP7 (and my assistant had the same problem with FCP6) the video clips speed up by about 0.15%. So a file that’s 12min 21sec long will import as 12min 19sec 20 frames (out of 23.98)
    I have about 80 interview clips where I have to sync the audio and it’s making it impossible to sync things up without going through a laborious workaround.
    STRANGE PART 2
    The files also get shortened on import to FCP X, however the multicam system on X syncs up the audio flawlessly. The irony is that FCP X sucks at exporting Multicam clips in XML files to FCP 7 (yes, I have Xto7)
    STRANGE PART 3
    I’ve gone back to past projects and tested out other files, shot on other cameras, and FCP has the same issue with all of them. No matter what version of FCP, the file shortens by a bit.
    STRANGE PART 4
    The files shorten on my computer AND my assistant’s computer
    POSSIBLE IMPORTANT INFO
    To give you a brief history:
    I recently went freelance and switched from 7 to X. Had a client who was giving me a lot of multicam stuff that I was editing with no problems in X. Decided to switch back to 7.
    Before going freelance, I usually shot and edit my own footage, but have recently been getting the .mov files without a camera directory structure from the client, which FCP X processes fine. Could the fact that I’m not importing directly from a camera (or folder w/directory structure) be causing this?
    Jessica Mantheiy replied 14 years, 3 months ago 2 Members · 5 Replies
  • Jessica Mantheiy
    June 20, 2012 at 10:06 pm
    Trent,
    Not having the correct directory structure available, I believe, would not cause the issue. What file types are you editing in that is 23.98 fps? Have you just tried slowing down the speed from the import setting of 100.15% to 100% (which I’m sure you have)?
    The time lengths you are specifying, you say, “So a file that’s 12min 21sec long will import as 12min 19sec 20 frames (out of 23.98).” Where are you getting the original “12:21” reading? What software?
  • Trent Watts
    June 20, 2012 at 10:13 pm
    Hey Jessica thanks for your reply, I’m getting it from reading the file info in the MAC OSX finder window.
    The problem is that it’s happening with every video file on my comp, so finding a temporary workaround like speed change doesn’t make sense. I can’t be slowing every clip down to 99.85% for every project I ever do after this.
  • Jessica Mantheiy
    June 21, 2012 at 12:36 am
    What file type are you working with? What are the specs? Also, checking the time length of the file in the finder window isn’t accurate. The best way to go would be to check in QuickTime Player X or QuickTime Player 7. It is more accurate.
  • Trent Watts
    June 21, 2012 at 6:28 pm
    found this thread on creativecow https://forums.creativecow.net/readpost/8/1151488
    I seem to be having the same issue….I’m on FCP 7, but X does it as well. And my friend says it happens on his machine? Is this just a big glitch that most people have but which has never caused major problems for people?
    I’m having audio sync issues as well, but it turned out this issue of changing durations was NOT the issue, as the clips synced up again once importing in the timeline.
    To test it, I took a 3 hour clip from a previous project and created a wav audio file from it. I then imported the wav file into FCP7 and it read as being about 11 seconds shorter than the video clip it was created from. But THEN in the timeline they synced back up.
    Took me a long time to realize this was NOT the culprit to the syncing issues on my current project
  • Jessica Mantheiy
    June 21, 2012 at 6:31 pm
    Have you tried anything besides a .wav file? Such as a .aiff?
    Jessica Muth
    Production Operations Manager
    Video Labs
    Rockville, MD
    301-217-0000
    jmuth@videolabs.net
