Activity Forums Blackmagic Design Filed problem on monitor using decklink and fcp
  • Filed problem on monitor using decklink and fcp
    Posted by Olav Verhoeven on June 1, 2006 at 10:01 am
    Dear All,
    Thanks for taking time to view this post.
    My problem is as followed, I’m always seeing fields on my monitor (PVM 14LE2) (DECKLINK CARD. downloaded the latest driver), I’ve tried every setting possible in the sequence setting, my project is based on uncompreesed 8 bit and I’m working with clips made in after effetcs (exported in Quictime compress = none + apha), I’ve have no clue wath to do next, I’ve tried also viewing dvpal files and they’re jurky as hell, on this clips I’ve tried filed filters, shift field, flicker and pal to sdi fields filter, nothing works, Easy setup in dvpal file works better but still their is jurky subtle things going on, desktop preview flicker also and espacialy the finder window and text in this.
    Many thanks for your considaration
    Olav
    Richard replied 20 years, 3 months ago 2 Members · 1 Reply
  • Richard
    June 1, 2006 at 3:18 pm
    What do you expect to see?
    If you are on a mac you could set (in System Preferences)the decklink card to display “Single Field Out When Paused”
    Richard
