Activity Forums AJA Video Systems File/Clip properties
  • File/Clip properties
    Posted by Craig Alan on March 26, 2011 at 5:32 pm
    Clip properties/render time question
    Canon hv40 HDV tapes captured/copied on
    Ki pro to apple pro res 422 imported to FCP dragged to timeline set to ‘match clip’.
    OSX 10.5.8; MacBookPro4,1 Intel Core 2 Duo 2.5 GHz
    FCP 6.0.6
    My problems began when I felt that all renders were taking too long.
    When I look at clip properties in browser
    I see
    Vid rate 29.97 fps
    FRAME Size: 1920 x 1080
    Apple pro res 422
    Pixel aspect: square
    Field dominance: upper (odd)
    The image looks fine but when I check clips from previous projects captured to apple pro res 422 in fcp directly the
    Frame size is 1440 x 1080
    and
    pixel aspect is (HD) 1440×1080
    Did I choose the wrong setting on the ki pro when I captured the HDV tapes on the Ki Pro?
    Does it matter at this point?
    The image looks fine to my eyes.
    Would these properties account for the long renders?
    If I need to recapture tapes, what setting should I chose on the Ki Pro?
    ; Camcorders: Sony Z7U, Canon HV30/40, Sony vx2000/PD170; FCP certified; write professionally for a variety of media; teach video production in L.A.
    Aja Sales department replied 15 years, 6 months ago 2 Members · 3 Replies
  • Aja Sales department
    March 26, 2011 at 7:57 pm
    This sounds like your Sequence Settings are not set to match your clip properties; Ki Pro only produces full raster video so it would not produce 1440×1080 thin raster, but 1920×1080. Set your sequence to match your clips to resolve the rendering.
    If you need further assistance, contact AJA Technical Support via phone or email Monday through Friday, PST.
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
  • Craig Alan
    March 26, 2011 at 9:41 pm
    Well I’m glad that I didn’t mess up the Ki Pro capture.
    Are square pixels correct?
    I think my clips and sequence setting match. Here’s the properties:
    March 28, 2011 at 4:35 pm
    Yes, square pixels is correct for full raster HD material. There appears to be a mismatch between your clip and sequence audio properties. You may want to contact AJA Technical Support if you need assistance with your Final Cut Pro settings.
    AJA Video Systems
    (800) 251-4224 US
    sales@aja.com
