  • Posted by Andi Blair on May 3, 2011 at 10:44 am
    Hi, I’m a newbie at Web Design ~ Here’s my question / problem.
    I have a Website :~ 1492DESIGN.COM which is being hosted by GoDaddy. It is live now.
    When I try to over wright a page using FileZilla, it goes through the motions of uploading, asks me if I want to over wright, Yes, yes I do, I can see on the FileZilla page it has done it, but when I check on my Website, nothing has changed.
    I have used Adobe Dreamweaver 8 ( I know, how very 80’s )to create my site. When I check it in Dreamweaver, it seems fine.
    But nothing changes to my Web site.
    I know Google does the Shallow / Deep sweep frequently, but my changes should change almost instantly on my site?
    Help please.
    Hassan Shahab replied 15 years, 3 months ago 3 Members · 2 Replies
  • Fernando Mol
    May 3, 2011 at 2:40 pm
    Could be your browser. Clear the cache and acces your site again.
    Also, if you describe your changes we can check them in the forum.
    I hope this helps
  • Hassan Shahab
    June 22, 2011 at 3:53 pm
    I don’t use filezilla I do it one of these ways.
    Nautilus (Ubuntu)
    Places > Connect to server
    Service Type: SSH
    Server: IP Address of the server
    Port: The port you set the server to
    Folder: /home//
    You can check the “Add Bookmark” box and it will show up under Places as Whatever you name it so you can just click on it like a folder.
    Click on Connect
    krusader (Kubuntu)
    Tools > New Net Connection
    Protocol: fish://
    Host: IP Address of the server
    Username: Your username on the host computer
    Password: Your password on the host computer
    Click on Connect
    gFTP
    Select SSH2
    Click on the icon to the left of Host that has 2 computers to connect (and disconnect)
    Dolphin (also has a split view to work on 2 folders at one time)
    Click on Networks on the left
    Click on Add Network Folder
    Select Secure shell (ssh)
    Click on Next
    Put in your Name
    Put in your Username (username on the host computer)
    Server: The IP Address of the server
    Folder: /home//
    Encoding: Change to (Unicode UTF- or whatever works for you
    Checking “Create an icon for this remote folder” is up to you
    Click on Connect
    Gigolo
    Click on Connect
    Service type: SSH
    Click on Connect
    The server will show up in the window (sftp for (username) on (IP Address of the server))
    https://gulfesolutions.com/
