Activity › Forums › VEGAS Pro › File stops loading at 53%
  • File stops loading at 53%
    Posted by Scott Onofrychuk on March 17, 2008 at 4:30 am
    I have a vegas video file that freezes when loading at 53%. I’ve left it loading overnight and it doesn’t budge. Any ideas on how to fix this? I’ve put many hours of my life into this file and I’d be mad if it went to waste. Thanks.
    Oh yeah, it’s Vegas 4.0 if it helps.
    Scott Onofrychuk replied 18 years, 6 months ago 3 Members · 3 Replies
  • Leslie Wand
    March 17, 2008 at 11:46 am
    little more detail would help. is it the .veg that’s not loading, an avi, or what?
    leslie
  • Edward Troxel
    March 17, 2008 at 1:07 pm
    Sounds like there’s something at 53% it doesn’t like anymore. Could be any of several things that are happening.
    First, I would check the .BAK file and see if that version works.
    Then I would try moving all the media files, open the project ignoring missing media, and see if it opens that way. If it does, then start reattaching the media one piece at a time.
    This is also a good time to mention creating a series of save files. For example, add a version number on the end of the file name and periodically up the number so you can always get back to a previous known working version. This is where my Auto Save custom command for Vegas Pro 8 comes in handy!
    If you have none of the above, then the only remaining options would be to redo it or see if Sony can help.
    Edward Troxel
    JETDV Scripts
  • Scott Onofrychuk
    March 18, 2008 at 8:04 am
    Oh wow I didn’t even know those .BAK files existed. Thank you very much, it fixed my problem!
