Activity Forums Blackmagic Design File sizes very large with Media Express
  • File sizes very large with Media Express
    Posted by Jim Arco on November 14, 2012 at 2:00 pm
    I have started capturing some old SVHS tapes (std resolution 4:3 NTSC) using Intensity Shuttle and Media Express. The files are much larger than I would expect – typically 6Gb for a five minute clip. I have hours of tapes to capture and will quickly run out of disk space at this rate.
    Is there some setting that would make file sizes more in-line with a captured DV tape? (about 13Gb per hour)
    Jim
    Mike Squires replied 13 years, 10 months ago 3 Members · 3 Replies
  • Mike Squires
    November 14, 2012 at 3:19 pm
    You’re probably capturing in uncompressed. Try MJPEG (motion jpeg), it gives nice results, and really cuts down on the file sizes.
  • Glenn Sakatch
    November 14, 2012 at 7:38 pm
    Uncompressed HD is about 1 gig per minute
    Glenn
  • Mike Squires
    November 14, 2012 at 8:04 pm
    Uncompressed SD is about 1GB per minute, HD is about 7GB per minute. (Assuming 8-bit 4:2:2).
