Activity Forums Adobe After Effects file size ? from render queue
  • file size ? from render queue
    Posted by Jeff Wolfram on March 6, 2014 at 7:38 pm
    I did a search and found some dated threads to this question so allow me to ask again. I’m using after effects cs 6 and I’m trying to find out if there is way to know my file size of a project in the render queue without a trial and error approach?
    Even if it’s a rough estimation is there a mathematical formula using it’s dimensions such as 4096×2304 20seconds at 24fps quicktime photojpg?
    I thought there was a way in after effects to know the file size prior to rendering.
    Any insights would be welcome.
    thanks, jeff
    Architectural & Interior Photographer
    Walter Soyka replied 12 years, 6 months ago 2 Members · 1 Reply
  • Walter Soyka
    March 6, 2014 at 7:57 pm
    [Jeff Wolfram] “I’m using after effects cs 6 and I’m trying to find out if there is way to know my file size of a project in the render queue without a trial and error approach?”
    The answer is: it depends. Different codecs work differently.
    Some codecs used constant bit rate encoding (or tightly-constrained variable bit rate). For these, each frame is expected to have about the same data size, so the file size is predictable — but the quality of the compression can vary in order to achieve that.
    Other codecs use quality-based encoding, which strives for constant quality at the expense of predictable bit-rate.
    Others may not fall into either of these categories; for example, “Uncompressed” is both constant bit rate and constant quality.
    [Jeff Wolfram] “Even if it’s a rough estimation is there a mathematical formula using it’s dimensions such as 4096×2304 20seconds at 24fps quicktime photojpg?”
    PhotoJPEG uses quality-based compression, so the size of the output is dependent on the source material.
    Walter Soyka
