Activity › Forums › VEGAS Pro › File size
  • File size
    Posted by Brian Parliment on October 28, 2008 at 11:05 pm
    I import a Handy cam file at 1gb into vegas 8.0b, make a cut, and a few overlays. Using the make DVD wizard for export to DVD architect, the file size comes out as 2gb. I tried it as preview and draft, neither reduces the size. DVD Architect can’t optimize this file because it was rendered for use in the DVD. How do I shrink the file size?
    Brian Parliment replied 17 years, 11 months ago 3 Members · 4 Replies
  • Douglas Spotted eagle
    October 29, 2008 at 12:39 am
    Reduce the bitrate when you export it.
    Sounds like you’re starting with a low bitrate file, and increasing it, if you’re starting with 1GB, not changing length, and ending with 2GB.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Brian Parliment
    October 29, 2008 at 12:57 am
    Do you change the bit rate in the properties? I don’t see a bit rate?
  • Mike Kujbida
    October 29, 2008 at 1:29 am
    It sounds like you’re using Vegas Movie Studio, not Vegas Pro which, as I recall, means that you don’t have the option to change the bitrate 🙁
  • Brian Parliment
    October 29, 2008 at 1:42 am
    That’s correct. Vegas movie Studio.
