Activity Forums Avid Media Composer file pixel to video mapping
  • file pixel to video mapping
    Posted by Tom Dempsey on November 22, 2009 at 3:43 am
    I’m a bit unfamiliar with Avid’s term when importing images. “File pixel to video mapping”
    could anyone explain in which ways one uses this? For example, if i’m working in 601 and
    my image is in RGB, which selection do i make. i.e., is it the file source or the file destination that
    it is video mapping? I’ve already searched avid’s forum and could not find an answer.
    greatly appreciated.
    tom
    Tom Dempsey replied 16 years, 6 months ago 2 Members · 2 Replies
  • Michael Phillips
    November 22, 2009 at 3:23 pm
    For color space, it is referring to the source. If you select RGB, it assumes that color space on source and maps/converts to REC601/709. If you select 601/709 it assumes you know the source is that and won’t touch any of the values. The target is always REC601/709 in the system.
    Michael
    Michael Phillips
  • Tom Dempsey
    November 23, 2009 at 2:12 pm
    thanks much.
    tom
