Activity › Forums › Apple Final Cut Pro Legacy › File Names on Export
Posted by Scott Davis on January 3, 2011 at 6:01 pmWhen I export a QT movie, granted it has a very long name, the file name ends up being cut off half way and some meaningless numbers and symbols are tacked on. Not that big of an issue as I can change it, just an annoyance.
Jeremy Garchow replied 14 years, 3 months ago 6 Members · 11 Replies -
Chris Tompkins
January 3, 2011 at 6:15 pmWhen you xport, you can create the name as you like.
Chris Tompkins
Video Atlanta LLC -
Scott Davis
January 3, 2011 at 6:18 pm -
Jeremy Garchow
January 3, 2011 at 7:31 pmIs this using the Batch Export feature by chance?
Yes, it has to do with long file names, but the name should change after the export is complete.
Oyvind Stiauren
January 3, 2011 at 11:50 pmThis has been a bug with FCP for a long time. What happens is that FCP makes a temporary file name during export of files with filenames over a certain length (I think it is 16 characters) and then re-names it after export is finished. But sometimes the re-naming is not done and the file ends up with the temporary name.
You can just re-name the file manually after the export is done, but there is one important thing you have to rememeber. FCP does not only re-name the file after exporting it. It also sets the reel number and timecode metadata in the same process. So whenever the re-naming process fails, the reel and timecode metadata is not set either. So this has to be done manually also.
Oyvind Stiauren
Post production supervisor, Colorist
TerminalMexico City
Scott Davis
January 4, 2011 at 12:15 am -
Oyvind Stiauren
January 4, 2011 at 12:30 amOhhh. Maybe a good practice when I have an export with a long file name is to temporarily name it something shorter on export and then rename at the finder level once export is complete to maintain metadata integrity.
Yes, you’ll avoid that problem all together doing that.
Oyvind Stiauren
TerminalMexico City
Andrew Grantham
May 21, 2012 at 7:29 pmReviving an old thread, I know, but the suggested remedy for this issue is incorrect. The file length is not at fault.
I just successfully exported a file, then tried to export the file again after a slight revision. The only difference in the new filename was an incremented number at the end.
Here are the filenames I attempted to save:
Interview – Guinea Pig final1.mov
Interview – Guinea Pig final2.movAnd here is what ended up on my HD:
Interview – Guinea Pi#987E9.movSo it would seem it’s not the length. It also can’t be the export or sequence settings since these were unchanged.
My vote is that it’s still a bug (as of FCP v 7.0.3 running on 10.7.3).
