Activity Forums Apple Final Cut Pro Legacy File Names Do Not Show Up in Reconnect Media
  • File Names Do Not Show Up in Reconnect Media
    Posted by Dustin Parsons on June 26, 2008 at 9:05 pm
    I just opened up a project I haven’t touched in a while and now most of the clips in my sequence require reconnecting (I don’t know why). The problem I’m running into is that when I click Reconnect Media the names for the files do not show up so not only does the Search not work but even if I wanted to reconnect them manually (which I don’t, that would take forever) I don’t know which clip I’m attempting to reconnect.
    Has anyone else run into this problem or have any guesses as to what my next move should be?
    Here’s what I’m seeing
    Dustin Parsons replied 17 years, 11 months ago 6 Members · 9 Replies
  • 9 Replies
  • Richard Sanchez
    June 26, 2008 at 9:19 pm
    I’ve had this happen to me before. I’m not sure exactly how it happens, but I would manually reconnect them. If you scroll through your timeline, it’ll show you the offline clip, and funny enough it always showed me the clip name. As long as you don’t change your clip names and they still reflect the name of the media file, you can manually reconnect them. It’s not fun, but that’s what I did.
    Richard Sanchez
    Arcadia, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Jeremy Garchow
    June 26, 2008 at 9:36 pm
    It appears the files that FCP is looking for are (or were) in the trash?
    Jeremy
  • Mark Maness
    June 26, 2008 at 9:37 pm
    Basically, it means that something has been corrupted. Usually this is a render file but sometimes its the dreaded media file that gone south for the winter.
    First, I’d try deleting all of your render files either in FCP after you get the message or deleting them before you open FCP. If its not that, you’ll have to painstakingly find the corrupt media file.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Aaron Neitz
    June 26, 2008 at 9:59 pm
    We just had the same thing happen today – during mid project the drive suddenly went offline. We had to go back 2 autosaves to get to a version that knew what the file names to reconnect to were
  • Jeremy Garchow
    June 26, 2008 at 11:02 pm
    The drive went offline?
  • Dustin Parsons
    June 27, 2008 at 8:42 pm
    The files aren’t in the trash, 3 of them were but the huge blank space under where is says ‘Root: is where all the media files should show up, instead it’s empty, like FCP knows how many files are missing, where they should be, but not their names (despite the fact that in the timeline they show up with the names).
    Mac OS X 10.5.3
    Mac Pro 2 x 2.66GHz Dual-Core Intel Xeon | 4GB Ram
    Final Cut Pro Studio 2
  • Dustin Parsons
    June 27, 2008 at 8:48 pm
    I just did the same thing and the media was still disconnected but at least the file names were showing up in the Reconnect Media window. *phew* Thanks!
    Mac OS X 10.5.3
  • Shawn Hamer
    October 14, 2008 at 2:41 pm
    I’ve just encountered this problem as well on a very large project with many short clips. Connecting these one at a time with no clip names pre-filled sucks….
    G5 Quad 2.5| FCP HD | Kona LHe
  • Dustin Parsons
    October 14, 2008 at 3:32 pm
    Try going back an Autosave or two. That’s what worked for me. The files were still disconnected but at least they had names and could easily be reconnected.
    Mac Pro | Leopard 10.5.3
    Final Cut Pro Studio 2 | Avid Media Composer
