Activity Forums Adobe Premiere Pro file name too long to be backed up
  • file name too long to be backed up
    Posted by Joe Bandy on March 17, 2009 at 11:03 pm
    I’m using adobe premiere CS3 on a Axio LE system and and having a problem backing up my projects.
    I back up my projects daily to external maxtor hard drives and usually have no problem except for the other day when I could not back up my preview files because the file name was too long. I’ve never seen this before and have backed up multiple projects this way to the same external hard drive. Since premiere determines the length and name of the preview files I cannot change them. I’m a little confused as to why this would not work in this case.
    I tried a separate external hard drive and received the same result.
    Rebecca Zoly replied 13 years, 3 months ago 3 Members · 3 Replies
  • Mike Velte
    March 18, 2009 at 10:41 am
    I would not be concerned with backing up preview files, they can be regenerated if ever needed.
  • Joe Bandy
    March 18, 2009 at 3:04 pm
    you are right, It’s not a huge problem if I can’t back them up. I’d still like to know what’s causing the problem though.
  • Rebecca Zoly
    June 18, 2013 at 11:53 am
    Long path tool is the best solution for your problem. try it and solve your problem.
