Activity Forums Apple Final Cut Pro Legacy File name display on video?
  • File name display on video?
    Posted by Chris Tomkins on March 9, 2010 at 1:52 am
    Does anyone know if there is a filter to write the file name over a clip (in the same way we used to use timecode display). I’ve got hundreds of DSLR clips that I’d like the client to choose their favourite takes, but I have no distinctive timecode on the clips, so they really need to know what they’re called..
    Also, is it correct to assume there is no way to “Log and Transfer” Canon 7D clips?
    Cheers
    Chris
    Daniel Frome replied 12 years, 6 months ago 12 Members · 19 Replies
  • 19 Replies
  • Arnie Schlissel
    March 9, 2010 at 3:43 am
    You can use a text generator to do this.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Chris Tomkins
    March 9, 2010 at 3:47 am
    Yes, I was hoping for something more automated than that. I have over 400 video files and I figured if Final Cut Pro knows the metadata of the name of the file, there might be a filter that would “burn” that information onto each clip, like with the timecode generator…
    Chris
  • Arnie Schlissel
    March 9, 2010 at 3:50 am
    I’ve never tried it, but you could look into Traffic from xmEdit.
    Arnie
  • Varun Saxena
    March 9, 2010 at 10:47 am
    U can do this just go to item properties of clip nd change the name of that
    what u want to.
    Regards
    Varun
  • Andreas Kiel
    March 9, 2010 at 11:24 am
    Hi Chris,
    You may try my free TCR Plus. It’s not an easy one step filter as there is no option within FCP to retrieve clip names or any other thing beside TC and Reel, but you can copy the clip name to the filter. There is an app which comes along with the filter which allows you to batch insert whatever you want from the basic comments, description etc. using XML, but that app is not free.
    https://www.spherico.com/filmtools/tcrPlus/index.html
    Regards
    Andreas
    Spherico
  • Eli Mavros
    March 9, 2010 at 4:31 pm
    I’m with you Chris, I’ve been wondering about such a plug-in as well. There have been many occasions when this would have been very useful. I hope someone knows of a plug-in.
    Best,
    Eli
    Eli Mavros
  • Daniel Frome
    October 3, 2010 at 6:30 pm
    Do this —
    1) Make a duplicate of your sequence
    2) right-click that new sequence “make sequence clips independent”
    3) right-click sequence and “make offline”
    The sequence now becomes a giant batch of “OFFLINE [filename]” visuals. Take this sequence, and drag it back over-top of the original sequence (which has the media still connected). Then crop off everything except the filename.
    It’s going to take a while to render out the new sequence – but it works.
    Apple should really just include a filter to do this… it’s really stupid.
  • Vlad Akhtyrskiy
    September 1, 2011 at 9:46 pm
    Best solution!
    Thank you Daniel.
  • Deyson Ortiz
    May 26, 2012 at 3:52 am
    Hello Daniel. You idea is ingenious. Now my problem is that when I make the copy offline the clips in the original sequence goes offline as well. I did do: 2) right-click that new sequence “make sequence clips independent”. Do you know what I may be doing wrong?
    Thank you and have a wonderful day.
    – Deyson Ortiz – Editor / Motion Graphics
    _______________________________________
    – View my work at: https://deysonortiz.com
    – Download Free Motion Master Templates at: https://motion-master-templates.com/
    – Watch my Apple Motion Podcasts at: https://my.creativecow.net/Deyson-Ortiz/podcasts
  • Daniel Frome
    May 26, 2012 at 11:50 am
    Oh man, it’s been almost 2 years since I made that post. Brings back memories.
    The “make clips independent” is the supposed to be the factor that turns this sequence offline, while keeping the other online. I am not sure why this isn’t working for you.
    There is also another solution using a paid product, TitleExchangePro. I ended up switching to that soon after using this method. It’s a bit more of an elegant solution.
    Lastly, I will admit that I switched to Avid a couple months after this I haven’t looked back. I mention this because this feature, if it’s important to you, is something that’s built directly into Avid’s timecode generator. You wouldn’t believe my relief when I found that out.
