Activity › Forums › Square Box CatDV › File Maker and Cat DV
  • File Maker and Cat DV
    Posted by Jack Bibbo on January 22, 2013 at 6:13 pm
    Can I import Filemaker Pro info into CAT DV.
    We have logged all footage via Filemaker, we are considering implementing CATDV however I could not imagine having to reenter all that meta data for a 450 hour film.
    thanks in advance
    jack
    Jack Bibbo replied 13 years, 8 months ago 3 Members · 3 Replies
  • Bryson Jones
    January 22, 2013 at 8:29 pm
    Yes, you can export in several formats out of Filemaker and import that into CatDV. (Sometimes a trip through Excel is nice to clean things up.)
    Tab Separated Text and XML both work.
    If you need to do this often, probably an XML with an XSLT to match CatDV’s import format is best.
    bryson
    bryson “at” northshoreautomation.com
  • Matthew Stamos
    January 24, 2013 at 2:53 pm
    Here is a link to an FAQ along those lines!
    https://www.squarebox.co.uk/faq145.html
  • Jack Bibbo
    January 24, 2013 at 6:36 pm
    excellent thanks guys.
