Activity › Forums › Avid Media Composer › File Conversion of Large Files
Posted by Jasmine Raphael on July 28, 2013 at 2:47 amHello, I am exporting a .mov file from Avid however it is more than 2GB. I need to convert the file to an M4V, however the only conversion software I’ve found is for .mov files that are 1GB or less (zamzar).
1) Do you know a way to export a .mov file from Avid of the assembly and make it less than 1 GB
OR
2) Do you know a way to convert a .mov file to a m4v file when the .mov file is larger than 1GBNOTE: The original Avid file is a 1 hour presentation with many layers of audio and video.
Peter Groom replied 13 years, 2 months ago 3 Members · 12 Replies -
Michael Phillips
July 28, 2013 at 6:02 amI usually render everything and export an QuickTime reference. From there I use a third party program as needed for the delivery.
Michael
Jasmine Raphael
July 28, 2013 at 6:33 amwhat is a quicktime reference file exactly? i’ll try that and see if it works.
Jasmine Raphael
July 28, 2013 at 5:22 pmOK I’ve tried iskysoft, wondershare, avs, adobe encode and a couple other conversion software and none of them have worked.
There has to be a way to get a movie i created in Avid to the m4v format to be able to play it on a samsung tablet.
help! i need advice!
Michael Phillips
July 28, 2013 at 6:49 pmWere you able to export a QuickTime Reference Movie? Form Export option, select QuickTime reference, then “mastering”. Export entire sequence and you will have an audio track and a movie file that is only a few Kb in size. For quick encodes, I drop the .mov file (the video one, not the audio) into MPEG Streamsclip and encode from there.
Michael
Jasmine Raphael
July 28, 2013 at 7:04 pmI exported the QT Ref file and it’s 800KB instead of 27GB. But when i put it into conversion software it says
The following errors occurred while opening files: QTRefBambi.mov – The specified file contains no video data
What does that mean?
Michael Phillips
July 28, 2013 at 7:10 pmCan you open the reference movie in MoviePlayer and play it? If there is no video, check your settings again on export from Media Composer. If the clips are still AMA linked, it will not work. A refernce video references Avid media, so transcode sequence to DNxHD, then export the transcoded sequence as a reference.
Michael
Jasmine Raphael
July 28, 2013 at 9:01 pmOK when I do the following I get a pop up in Avid that says “Exception: UPDATE_MOVIE_RESOURCE_FAILED”. What does that mean and what am I doing wrong?
1) Open Avid
2) Open the project I’m working on
3) Go to File > Export
4) A box opens and says “Export As…” and I choose “Quicktime Reference File” and open Export Settings – QuickTime Reference which says:
Export As: Quick Reference (use marks and use enabled tracks are NOT checked)
Defaults: Digital Mastering
Flatten Video Tracks CHECKED
Fill Spaces with black CHECKED
Render All Video Effect CHECKED
Display Aspect Ratio NATIVE DIMENSIONS
Mixdown Audio Tracks CHECKED
Audio Format AIFF_C
Sample Rate 48 kHz
Bit Depth 16 Bit
Use Network Media References UNCHECKED
Use Avid Codecs UNCHECKED
Color Levels 601/709 -
Michael Phillips
July 28, 2013 at 9:13 pmIs your sequence DNxHD or AMA linked or some other codec other than DNxHD?
Jasmine Raphael
July 28, 2013 at 9:45 pmSo here’s the thing:
I exported the project as a mov file sucessfully. the movie file plays great in QT player. The file is 27GB.
OK now, so I try to convert that to a m4v file and what happens is the audio is fine but in the beginning of the project it just deletes some of the video. It shows the png files that are laid on the tracks just fine, but the video is not there.
So what do i do with that?
