Activity Forums Adobe Premiere Pro Fields problem with colour correction
  • Fields problem with colour correction
    Posted by Dickij on July 6, 2006 at 8:14 pm
    Has anyone got any advice on this one?
    When I apply a colour correction as well as a scale (in the Motion tab) to a clip, the playback of the fields is wrong. It looks like either the field order is swapped or the Motion dve is doing a frame-based interpolation on the video. Clips with no effects on them playback with the correct field motion. Clips which are scaled in Motion will render and playback with the correct fields. Clips which have both colour and scale applied exhibit this horrid jaggy field problem on moving portions of the video.
    Dickij replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
