Activity › Forums › Apple Final Cut Pro Legacy › Fields, fields…
  • Fields, fields…
    Posted by Alec Gitelman on August 28, 2007 at 5:10 pm
    I’ve recently completed a 30 sec spot for an ethnic cable channel.
    I’ve shot HDV 1080i50, converted it to DVCPRO 1080i50, scaled and repositioned it in a SD PAL Sequence. Final Delivery was in AVID Meridien Compressed 3:1.
    Now, as far as i know and see, all these formats are upper field first. I made sure the sequence was upper too. Now the cable station is saying the fields are flipped, or something of that order (communication with them is limited).
    I checked and I don’t see any problems. However I don’t have a PAL monitor, so I may not see everything. Can something happen during scaling and positioning? I remember removing a few Shift Field filters because I felt they were making the image soft, but now I’ll never remember where and why I did that.
    Does anyone have any advice? If you’d like, you can see the file I sent to the cable station here:
    https://maxf.net/~alichek/cojeco/CojecoCharity30sec_0824_Ch1Specs.mov
    i also suspect they may be needlessly busting my chops.
    I’ll appreciate any advice. I would prefer not to go back all the way to recompressing the original HDV footage.
    Martin Baker replied 19 years, 1 month ago 4 Members · 6 Replies
  • Rory Brennan
    August 28, 2007 at 5:29 pm
    My guess is that you didn’t flip the fields, but rather they need lower (even) fields first. SD PAL is lower field first.
  • Alec Gitelman
    August 28, 2007 at 5:52 pm
    not the case…
    AVID Meridien Compressed Codec with settings:
    Video Format: PAL (720×576/25fps)
    Color Input: RGB
    Resolutions: 3:1 Interlaced
    Upper field first
  • Walter Biscardi
    August 28, 2007 at 5:55 pm
    [alichek] “not the case…”
    Uncompressed PAL, yes.
    DV PAL, no, that’s lower field first.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Walter Biscardi
    August 28, 2007 at 5:56 pm
    What happens if you simply deliver as an Animation Codec project and let them re-render in their Avid?
    I never had luck exporting with any Avid codec on our systems so if I have to send to an Avid system, I simply use the Animation Codec. It’s worked brilliantly here for 4 years now.
  • Alec Gitelman
    August 28, 2007 at 6:06 pm
    well, i posted their specs, which are what you’ve seen. i wish i could send them animation codec, but i don’t have a direct contact with them, only through the advertising agency that subcontracts me.
    in any case, i’m sticking with upper first throughout. any ideas? i can take it through my avid xpress pro, but that will only add two recompressions to the footage and doesn’t avid use quicktime compression on export anyway?
  • Martin Baker
    August 29, 2007 at 5:16 pm
    Most of the shots are correctly Upper Field but two are Lower:
    2″ – opening door
    15″ – cu girl turning
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    Avid2FCP
    For Avid editors learning FCP
