Activity › Forums › Adobe After Effects › Field/flickering from Premiere Pro to Windows Media
  • Field/flickering from Premiere Pro to Windows Media
    Posted by Ed Hecht on September 26, 2011 at 10:46 pm
    I’m getting weird line flicker from line drawings in files after exporting to WMV or even QT (H.264). The static line drawings are originally exported from PowerPoint as jpegs, then animated with overlays in After Effects. Oddly, it only seems to happen in the parts of the file where there are multiple layers. Flicker Removal in Field Options (in Premiere Pro) is a short-term solution as it minimizes, but doesn’t completely eliminate the problem. (Frame Blend distorts the image/fonts too much.) Is there a setting to tweak in AME to prevent this? Decoder complexity or keyframe interval? Please, this grasshopper seeks to snatch the pebble from your hand…
    Ed
    Roland R. kahlenberg replied 15 years ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    September 26, 2011 at 11:53 pm
    Try setting keyframes to every frame in Encoder. If that does not do it, apply a blur (gaussian or fast blur) in AE of 0.3 – 0.7 on the parts where you get flicker.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Roland R. kahlenberg
    September 27, 2011 at 2:26 am
    Remove Flicker should work, it all depends on the value you set. Before applying it though, you will want to reduce the levels output to 16-235 – pure black and pure white areas are more likely to flicker to due chroma crawl artefacts which happens in areas of high contrast.
    So yeah, you get two artefacts compounding the flickering that you see.
    HTH
    RoRK
    Intensive AE & Mocha Training in Asia.
