Activity Forums Adobe After Effects field render problem!!!
  • field render problem!!!
    Posted by Todd Morgan on December 19, 2006 at 1:37 am
    I am having a problem with fields. I have footage rendered from Max (tga seq) with lower fields, 30fps (NTSCD1). Import them into AE7 and create comp. Render out to final file format (AvidQT codec) and I get an interlacing problem with that layer. The tga sequence giving me the problem seems to work fine when the sequence starts at its 0 frame in the comp. But if I trim the layer so that at comp frame 0 the tgs seq in point is at frame 30, I get an interlacing problem. I don’t get it. I am not moving the layer position at all, so why should it matter where I trim the tgs sequence for it to start at frame 0 in the comp? Any one else have this problem? As I write this I did a test with the tga sequence in point at frame 0, starting at comp frame 0 and it works fine.
    Thanks in advance!
    Todd
    Todd Morgan
    morgancreative
    Todd Morgan replied 19 years, 9 months ago 2 Members · 2 Replies
  • Mylenium
    December 19, 2006 at 6:29 am
    Not entirely sure, but are you certain you haven’t incidentally slipped it just a tiny bit beyond the actual mark or are working in a 29.97 comp whereas your footage is 30 fps and something with the interpretation might not work out? In that case AE would sample the wrong field. I can’t really provide any further solution to this.
    Mylenium
    [Pour Myl
  • Todd Morgan
    December 19, 2006 at 6:39 pm
    ahhhh…. it is at 30 fps. Thanks!!!
    Todd Morgan
    morgancreative
