Activity › Forums › Apple Final Cut Pro › Field Order changed by FCPX
  • Field Order changed by FCPX
    Posted by James Bayliss-smith on January 2, 2012 at 9:50 am
    I’ve just completed a PAL edit with footage from P2 DVCpro using FCP X
    After exporting from FCPX and trying to compress using a program called M-Link Newscaster I got a warning message saying
    “This looks like a PAL video but but has an unexpected field order (top field first)”
    Sure enough when I analyse the output file in VideoSpec it says the top field is first. When I analyse the footage (that I ingested with FCP 7) it is bottom field first. SO it has changed during the edit
    Why has FCP X done this?
    Does it matter (I have a feeling it does my content is destined for television news)
    How do I solve this problem?
    Cheers
    Oliver Peters replied 14 years, 9 months ago 3 Members · 2 Replies
  • Ben Scott
    January 2, 2012 at 11:11 am
    broadcast signal for PAL is normally upper field
    DV and DVCpro are lower field
    I would say leave as upper field
    unless you are seeing field reversal, check by making DVD or something like that, or step through field by field in FCPX and check it isnt reversing from field to field, option right arrow
    if you are getting field reversal I suggest changing the project settings to match the source content of DVCpro and then use compressor to change field order
    if you need to change the project settings in FCPX (and so change the field order) press command J and then click the little spanner on the left in info panel
  • Oliver Peters
    January 2, 2012 at 5:16 pm
    It’s worth noting that FCP X no longer works in the DV world the way FCP 1-7 did. Yes, I know you can select DV variants to SD sizes, but you can no longer work with the DV codec as a rendering format, which is part of the equation. It’s best if you fit your DV content into a standard SD (uncompressed/ProRes) frame size and position vertically to optimum quality. Then export through Compressor cropping as needed.
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
