Activity › Forums › Adobe After Effects › Field Issues
Field Issues
Posted by Thomas Eldred on May 7, 2009 at 4:02 pmI am having field issues with a project that I created in AE and imported into an AVID Media Composer. The file is uncompressed and set to render the lower field first…have I missed step? Thank you.
Steve Roberts replied 17 years, 4 months ago 2 Members · 8 Replies -
Thomas Eldred
May 7, 2009 at 5:02 pmI rendered lower field first but I’m a little lost on interpret. Where would I find this?
Thomas Eldred
May 7, 2009 at 5:25 pmFound it. The “seperate fields” box was off…should I have it set to lower field first? Also will I still need to make sure that I select “lower field first” in render settings?
Thomas Eldred
May 7, 2009 at 6:45 pmI rendered a 720×480 square pixels comp and I still got the field issue.
Thomas Eldred
May 7, 2009 at 6:58 pmSounds good, I’ll try making comp same as soure. Thank you for your help.
Thomas Eldred
May 7, 2009 at 7:12 pmThat did the trick. It worked great when I imported it back into the AVID. When I dragged the QT clipped that I exported from my Avid it created a comp sized at 720×486 NTSC D1 with the D1/DV NTSC (0.91) pixel aspect ratio.
Steve Roberts
May 8, 2009 at 5:53 pm[Dave LaRonde] “… simply drag your clip onto the Make Comp icon at the bottom of the project window, and you get a comp in you’r clip’s resolution and length.
“I always do that when working with a comp that needs to match footage. Avoids human error.
