Activity › Forums › Apple Final Cut Pro Legacy › field issues with sapphire pluggins in FCP
  • field issues with sapphire pluggins in FCP
    Posted by Paul Nevison on September 28, 2005 at 7:56 pm
    when applying some sapphire pluggins to graphic psd elements i get terrible field issues that distort the image….if i apply a blend fields filter it fixes the problem but only if the blend fields filter is below the offending sappire pluggin in the filter stack.
    any graphics gurus know what’s going on here?
    thanks
    G5 DP 2.0
    2.0G RAM
    OS 10.3.8
    QT 6.5.2
    FCP HD 4.5
    CineWave 4.7
    Cinewave RT Pro
    Pro Digital Plus & Pro Analogue BOB
    Gary Oberbrunner replied 21 years ago 2 Members · 1 Reply
  • Gary Oberbrunner
    September 30, 2005 at 7:46 pm
    Hi, Paul. See here: https://www.genarts.com/sapphire-ae-support.html#fcp-graphic
    FCP can have frame corruption problems when a plug-in is applied directly to a graphic with an odd height, such as a psd or jpg image. The workaround is to nest the graphic in a subsequence, and apply the plug-in to the nest instead to the original image. Hopefully this problem will be fixed in a future version of FCP.
    — Gary
