Activity Forums Apple Final Cut Pro Legacy Field issues with material delivered as Targa seq with fields.
  • Field issues with material delivered as Targa seq with fields.
    Posted by Damian Smerdon on October 20, 2009 at 4:35 am
    Howdy.
    We’ve had a 3D animation company put together an animation for a TVC. Initially they outputted it as progressive QT but it looked too jittery on playback so we asked them to put it out as interlaced (they delivered targas)… now I can’t seem to get it to playback properly at all.
    I’ve tried taking it through AFX, setting the interpretation as upper, lower, none… outputting as prores, animation, final cut uncompressed… I just can’t get it right…
    Anyone have any helpful suggestions for me…
    I’m wasting too much time… and the client wants it on air very soon.
    Arrrrgghhh.
    Arnie Schlissel replied 16 years, 11 months ago 3 Members · 2 Replies
  • Rafael Amador
    October 20, 2009 at 11:25 am
    Hi Damian,
    Out of Upper, Lower and Progressive there in no other option.
    Try to open the sequence in an application that can step field by field (AE, Shake,.).
    When you change the field order in the clips, I guess that you change it in the sequence too, don’t you?
    rafael
    http://www.nagavideo.com
  • Arnie Schlissel
    October 20, 2009 at 1:24 pm
    Jittery on what kind of monitor? What size & frame rate are the targas? What are your sequence settings in FCP?
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
