Activity Forums Apple Final Cut Pro Legacy Field Issues when Importing Progressive Animation
  • Field Issues when Importing Progressive Animation
    Posted by Nick Haffie-emslie on December 14, 2008 at 8:37 pm
    Hi guys, wondering if you can help me out with something.
    I’m working in FCP (studio 2) on a 29.97 SD 4:3 Progressive ProRes sequence.
    I’m exporting graphics out of After Effects in Lossless Progressive QuickTime Animation (100%) with an alpha channel.
    These look crisp in QuickTime, but when I bring them into FCP they lose half of their vertical resolution and their properties say they’re Lower/Even, not progressive.
    Opening the files in QuickTime, going into their properties, and checking “Single Field” does not resolve the issue. Is there some way I can force FCP to recognize that these files are progressive? Is there something I might be doing wrong in AE? (I’m set to Off in Render Settings > Time Sampling > Field Render, and when I go ProRes out of AE there are no problems).
    Any ideas about why this might be happening?
    Rafael Amador replied 17 years, 8 months ago 5 Members · 20 Replies
  • 20 Replies
  • Arnie Schlissel
    December 14, 2008 at 11:06 pm
    It sounds like you rendered out of AE with fields. the only way to fix this is to re-render without fields.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Jeremy Garchow
    December 14, 2008 at 11:36 pm
    Yeah, FCP is misinterpreting your progressive movie as interlaced (since it expects 4:3 SD to be lower field first n NTSC). In the FCP browser, find the field dominance column and change it from lower to none. Then add the clip to your progressive timeline.
    Jeremy
  • Nick Haffie-emslie
    December 14, 2008 at 11:56 pm
    Hmm, I’ve been poking around in AE but when using the Animation codec, I believe the only place to specify field handling is in the Render Settings, where I’m set to Fields Off. (When going out to ProRes, you have an additional option in the codec settings, but not so with Animation).
    I have a 6-frame sample clip if someone would like to try it out:
    https://www.4shared.com/file/75991734/b2ab7148/FieldTest.html
    I seem to lose every other line of this test clip when dropping it on a progressive SD sequence. Does this happen for you?
    December 15, 2008 at 12:00 am
    D’oh!
    Thanks Jeremy!
    So FCP looks at the frame size and frame rate and assumes it’s NTSC DV material, even if there is nothing in the file to indicate interlacing?
  • Jeremy Garchow
    December 15, 2008 at 12:25 am
    That’s what I think, yep. It seems to happen like this all the time. When and if you send out to compressor, make sure to set your field dominance for your exported movie in the a/v settings tab of compressor so that it too knows your movie is progressive.
    Jeremy
  • Rafael Amador
    December 15, 2008 at 4:30 am
    This is not an FC but a QT issue. Whatever the application you use (FC, Shake, AE,..) you must make sure that the field order is properly interpreted. It seems that QT do not have a field-dominance flag.
    Rafael
    http://www.nagavideo.com
  • Chris Borjis
    December 15, 2008 at 5:37 pm
    [Rafael Amador] “This is not an FC but a QT issue. Whatever the application you use (FC, Shake, AE,..) you must make sure that the field order is properly interpreted. It seems that QT do not have a field-dominance flag.”
    agreed.
    I’ve never seen this problem in my work.
    exporting a quicktime animation or png video out of after effects (I NEVER render to fields)
    then importing into a final cut prores or uncompressed 10-bit sequence…it always just works.
    December 15, 2008 at 5:56 pm
    And I’m pretty sure I’ve had this workflow go fine in the past… strange.
    What’s interesting is that exporting ProRes of the exact same comp in the same dimensions and frame rate from AE works fine: FCP realizes it’s progressive without being told. Are we sure the QT file format has no field order flags for any codec? Perhaps additional metadata is included in the ProRes?
  • Jeremy Garchow
    December 15, 2008 at 6:11 pm
    [Nick Haffie-Emslie] “Perhaps additional metadata is included in the ProRes?”
    It is as you had pointed out. There an in ‘interlaced’ check box in the ProRes codec that is not in the Animation codec. I think this is codec and also format specific.
    Jeremy
  • Rafael Amador
    December 15, 2008 at 6:44 pm
    Yes as you and Jeremy points must be something in the codec.
    The DV Anamorphic footage captured with the BlackMagic DV codec plays 16×9 in QT. You don’t get that with the Apple DV unless you change the properties.
    Rafael
