Field edits on 720p to 1080i on Kona output
Hello,
I have received a timeline on FCP 7.x that is 720p 59.94. Opening it up it says it is a 59.94 timebase. So far so good. I am using the Kona card to output to another device for colour grading. I could not get the output to tape function working. It would just show me a still frame on output. When outputing live it was working fine. So I output live.
Now I have noticed that 90% of the outgoing shots before each edit have a field edit on it. That is field 1 is the previous frame of the outgoing shot, field 2 is the next frame of the incoming shot. When I inspect the timeline on the finalcut, edits are correct. It seems to be pulldown added as the conversion happens from 720p to 1080i. Even though the timebase of both are 59.94. (If this was a 23.976 timeline where pulldown is added to make NTSC I would understand) but this is baffling me.Thanks for any info or explanation.
JeffJeff Krebs
triangle
