Activity Forums Apple Final Cut Pro Legacy Field dominance when text and graphic for pal! -to digibeta.
  • Field dominance when text and graphic for pal! -to digibeta.
    Posted by Max Christensen on August 17, 2009 at 1:34 pm
    I feel kinda stupid asking this question now. Especially after working with this for over a year. But..
    I’ve been looking trough the net, for the best field-dominance when doing PAL digibeta sequences. In the final cut pro setup.
    Upper or lower? when starting a sequence?
    I include graphics sometime, and text etc.
    Thnak you my all knowing Jedi’s.
    Rafael Amador replied 17 years ago 3 Members · 2 Replies
  • Adam Taylor
    August 17, 2009 at 1:56 pm
    In PAL – always use upper field first. The only time this is otherwise is if you are working in DV, but as you are going to digibeta…then definitely upper (or odd).
    adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Rafael Amador
    Hi Max,
    Pal DigiBeta is Upper first.
    NTSC lower.
    cheers,
    rafael
    http://www.nagavideo.com
