Activity Forums Apple Final Cut Pro Legacy Field Dominance Settings for HDV Output in DVD
  • Field Dominance Settings for HDV Output in DVD
    Posted by Stefani Natalia on February 13, 2007 at 9:01 pm
    I am working on an HDV (720p30) editing of which output will be in a DVD format (4:3 Letterbox). I exported it as a Quicktime with NTSC MPEG-4 Compression. The Quicktime by itself looks fine when I play it on TV screen. However, I burned it into DVD and played the DVD on the same TV screen, then I can see jagged lines everywhere in the video. What is the problem here?
    Uli Plank replied 19 years, 6 months ago 2 Members · 1 Reply
  • Uli Plank
    February 14, 2007 at 7:44 am
    You’ll need to de-interlace or do a interlaced downscale (try Compressor
