Activity Forums Apple Final Cut Pro Legacy Field Dominance question
  • Field Dominance question
    Posted by Matthew London on March 29, 2006 at 4:59 pm
    I just recaptured a project which was in DV res “Lower (Even)” field dominance, to Uncompressed 10bit “Upper (Odd) field dominance.
    The new Uncompressed clips show up in my browser as “Upper (Odd)” but when I select a clip in the timeline and view Item Properties, it shows Field Dominance as “Not Set”
    Is this a problem? If so, how to fix in a batch? (I have 100’s of clips…)
    I don’t think any of the Paste Attribute commands will work here.
    Thank you….
    Matthew London replied 20 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
