Field Dominance Issues?
I have been happily using my Kona 3/ 2.5Ghz G5/ Fibrechannel Raid setup to capture SD 10 bit uncompressed from Dbeta unitll recently I noticed that some of the captured quicktimes have what looks like a field dominance issue.
This is not happening purely on the cuts but if I park it on the frame where there is a cut I see one field from the previous shot and another from the following shot. I looked at settings for field dominance and you can only change the sequence settings…not the capture. Everthing is now set to Lower field dominance. When I go back out to tape and park the tape on the same cut then it is fine. Only when I try and compress something do these odd frames show up.
Is this happening in quicktime or through the AJA or somewhere else in the path?
