Activity › Forums › Apple Final Cut Pro Legacy › Field dominance issues
  • Field dominance issues
    Posted by Tom Duncan on October 8, 2007 at 4:09 pm
    I’ve been having trouble getting a sequence from DVCPROHD 720 out to NTSC DVD, the image on DVD sometimes looks jagged or broken up with a general terrible quality to it. It looks worse during certain bright scenes.
    I had thought the image was breaking apart during the compression as the image looks fine in HD. Also seems fine downcoverted to NTSC 8-bit uncompressed, but when I compress it to mpeg it looks terrible on a monitor.
    Looking a little deeper and I realize the HD clips are set to upper field dominance. I don’t know how, but it must have occurred during capture(?) and I just now discovered this now that the film is finished.
    When I drop the HD sequence into the 8bit uncompressed sequence, FCP automatically applies a “shift fields” +1 filter.(?) The image appears to look fine at this stage until I compress out to mpeg, then it crumbles.
    What do I want to do at this point to get this into mpeg? Should I remove the shift fields filter since DVD is upper field anyways? Change the NTSC sequence to upper field dominance? De-interlace? Was the footage captured incorrect and how would I undo the problem going from DVCPRO720 to NTSC DVD?
    thanks, td
    Rafael Amador replied 18 years, 11 months ago 4 Members · 4 Replies
  • Shane Ross
    October 8, 2007 at 4:15 pm
    #42 – Quick and dirty way to author a DVD
    Shane’s Stock Answer #42 – David Roth Weiss’ Secret Quick and Dirty Way to Author a DVD:
    The absolute simplest way to make a DVD using FCP and DVDSP is as follows:
    1. Export a QT movie, either a reference file or self contained using current settings.
    2. Open DVDSP, select the “graphical” tab and you will see two little monitors, one blue, one green.
    3. Select the left blue one and hit delete.
    4. Now, select the green one, right click on it amd select the top option “first play”.
    5. Now drag your QT from the broswer and drop it on top of the green monitor.
    6. Now, for a DVD from an HD source, look to the right side and select the “general tab” in the track editor, and see the Display Mode, and select “16:9 pan-scan.”
    7. Hit the little black and yellow burn icon at the top of the page and put a a DVD in when prompted. DVDSP will encode and burn your new DVD.
    THATS ALL!!!
    NOW…if you want a GOOD LOOKING DVD, instead of taking your REF movie into DVD SP, instead take it into Compressor and choose the BEST QUALITY ENCODE (2 pass VBR) that matches your show timing. Then take THAT result into DVD SP and follow the rest of the steps. Except you can choose “16:9 LETTERBOX” instead of PAN & SCAN if you want to see the entire image. This is what I do for my DVCPRO HD projects to get them onto DVD…and I have no field issues whatsoever.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Tom Duncan
    October 8, 2007 at 4:28 pm
    Thanks Shane for the response. I’ve been doing what you suggested and at that stage (DVD) the image looks terrible.
    I think you are suggesting that this is not a field issue and that FCP, Compressor and/or DVDSP are managing the field orders irregardless of how the clips were captured. (?)
    If that is the case it goes back to what I had first suspected which is that the brighter scenes are causing Compressor to degrade the image. I tried applying the broadcast safe filter which didn’t seem to help either. Any ideas?
    thanks,td
  • Jeremy Garchow
    October 8, 2007 at 4:31 pm
    Let me guess, this is in FCP6, correct? THat shift fields thing is a bug and annoying as all get out.
    720p is progressive, are you sure you have your sequence setup properly? There’s no way it should have captured with fields. What frame rate are you working in?
    You should make a DVD from the HD material, and not render down an SD timeline. If you are working @ 23.98, keep the DVD @ 23.98 and make sure you tell compressor that your footage is progressive 23.98 and to keep it that way.
    Jeremy
  • Rafael Amador
    October 9, 2007 at 9:17 am
    You have an interlacing mess. Yous should start checking the field order of your footage. You can do it in Shake or in AE.
    Another matter is, don;t let Compressor guess the field order of your movie. Set it manually in the “Video Format” tab of the compressor. Compressor expect always the DV movies to be lower-first, but this is not always like that. If you feed Compressor with a Dv movie upper-first, Compressor will set the wrong field order, unless you tell him the correct one. In DVDSTP you have not the chance of setting the proper field order.
    Rafael
