Activity › Forums › Blackmagic Design › field dominance for DVCPro HD
  • field dominance for DVCPro HD
    Posted by Alisa Placas on April 18, 2005 at 5:40 pm
    I normally render After Effects SD animations lower field first with the Blackmagic codec.
    I’ve read that HD is upper field first though.
    Should I render UFF with the DVCPro HD codec to view HD animations on a Decklink? Or should it still be lower field?
    I know that I should be able to render both and see which looks correct. I’m having some motion jitter problems with my animations though and both UFF and LFF are looking pretty much the same to me at the moment.
    alisa
    Luke Maslen replied 21 years, 5 months ago 2 Members · 1 Reply
  • Luke Maslen
    April 19, 2005 at 1:21 am
    Hi Alisa,
    I believe you should just copy the settings that you can see in Final Cut Pro HD for the DVCPRO HD easy setups. In other words, set the field dominance to Upper field first for interlaced HD (eg 1080i60) and set it to None for progressive HD (eg 720p60).
    Regards,
    Luke Maslen
    Blackmagic Design
