Activity › Forums › Media 100 › Field Dominance and Encoding
  • Field Dominance and Encoding
    Posted by Bryon Middleton on October 9, 2007 at 12:59 pm
    I am trying to export a spot from my media 100 in order to encode it to specifications that meet DG FastChannel (a digital video distributer) specifications. The one problem that i keep running into is no interlaced frames are showing up. All my settings in Episode (encoding program) are correct, so i figure it must be the codec or something when i export from Media 100. I have included the email i recieved from DG’s tech support. Any help on this subject is greatly appreciated.
    thank you.
    (FORWARD)
    **Unfortunately, this spot has the same problem as the last one. There are no interlaced frames showing up. Have you checked on the Field Dominance settings for both your softwares (UpperxUpper, LowerxLower) ?
    Spot failed
    S:\OutputDir>analyze TEST21.mpg -v
    Version=1.8
    FileName=TEST21.mpg
    HorzSize=720
    VertSize=512
    AspectRatio=1×1
    Progressive=no
    Chroma=4:2:2
    TopFieldFirst=no
    ClipMail=no
    PictureStructure=2
    DGTypeCode=12
    StreamType=”Program Stream”
    VidType=”4:2:2 Chroma – 480/30i – lower field first – MPEG2″
    AudType=”2 channel MPEG-1 Layer II audio”
    ErrorCode=0
    WarningCode=2
    Floh Peters replied 18 years, 11 months ago 2 Members · 1 Reply
  • Floh Peters
    October 9, 2007 at 3:08 pm
    So how do you export from Media 100? You should export as “By Reference”, and then use e.g. Episode to do all the transcoding. Make sure that you set Episode to correctly read your source footage settings. I am not really sure that there is something wrong with your export from Media 100 (since Media 100 usually does not remove fields when exporting), I would expect that either your source footage is progressive, or there is something wrong in your Episode settings.
