Activity › Forums › Apple Final Cut Pro Legacy › field dominance 101
  • field dominance 101
    Posted by J. Tad newberry on June 9, 2007 at 5:00 am
    actually, i think i need the class even below 101….
    anyway, i’m wanting to bring an animation from Lightwave into FCP, and am having a heck of a time getting the field order/dominance correct. my FCP timeline is all the default settings for Blackmagic NTSC – DV which has the field dominance as lower/even. in Lightwave, i’ve rendered a test animation each of three different ways: one with no field rendering, and one each of even first, and odd first. they all three look crappy (jumpy/jittery) in FCP. what am i doing wrong THIS time, Cletus?
    Rafael Amador replied 19 years, 3 months ago 3 Members · 2 Replies
  • Bill Russell
    June 9, 2007 at 5:36 am
    Hmm, make sure your output is 720×480 (the size for DV) and not 720×486 (the size for uncompressed). The lines of of the fields must match up exactly. And I assume your DV project is 29.97 (and not 23.976)? Anyway, if all three versions jittery, sounds like perhaps a frame rate mis-match. Check that on your lightwave project.
    “THE LOST SKELETON OF CADAVRA” –
    And more…
  • Rafael Amador
    June 9, 2007 at 4:31 pm
    Whatever think that you export in DV will look crappy. Choose a better codec and if you go to edit in a “lower-first” time-line, export your animation “lower-first”.
    Rafael
