Activity Forums Apple Final Cut Pro Legacy Field-based rendering in FCP?
  • Field-based rendering in FCP?
    Posted by Mark Arenz on March 1, 2006 at 1:30 pm
    This is probably a very dim question but I could not find anything like it while searching so here goes:
    I’ve never been fond of how dissolves & fades look in FCP. Mainly, its the way FCP renders them in frames rather than fields- so the transitions seem stair-stepped in time. I’ve checked my video settings and lower dominance is set and the D1 video looks fine and most transitions seem smooth. So, is just that some transitions just can’t do fields?
    Fades to black, dissolves, and even ramping a slug’s opacity in & out for a cheap downstream black- all of it has this strange look that bothers no one here but me.
    FCP 4.5 on OSX 10.3.9 using a Blackmagic Decklink d1 card
    Mark Arenz replied 20 years, 7 months ago 2 Members · 2 Replies
  • Walter Biscardi
    March 1, 2006 at 1:33 pm
    You’re probably set to a lower resolution in your Sequence. Set your Playback and RT settings to Full Quality.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Mark Arenz
    March 1, 2006 at 2:25 pm
    Already did that. The sequence is set to full res/uncompressed 10 bit.
    I did notice something interesting, though. If I did the same setup with another transition it rendered in fields no problem. I think it’s an issue with the transitions themselves. If you use the default cross-dissolve it will render in frames to save time. I’m fairly sure that’s why “fade in/out” dissolve exists- because it renders in fields. I now have a work-around but I’m still not sure why.
