Activity › Forums › Apple Final Cut Pro Legacy › Fianl Cut Problem with new INTEL MAC
Jeremy Garchow replied 19 years, 11 months ago 4 Members · 14 Replies
Icvdave
October 20, 2006 at 10:11 pmGary,
Scratch disk is set correctly.
We just spoke to intel again and they said basically the same thing.
2 gb max. and use 2 – 1gb modules. Currently we are running 1 2gb module!
thanks for all the ideas
we’ll see how the new ram performs
Jeremy Garchow
October 20, 2006 at 11:36 pmYes, that could be your problem. ALso, i have assumed you have run the firmware update for your MacPro, or is this silly for me to assume?
Your ‘systems integrator company’ needs to bone up on the idiosyncrasies of the MacPro.
Also, see this article about proper RAM configuration:
https://docs.info.apple.com/article.html?artnum=304492
You shouldn’t just have one stick.
Icvdave
October 20, 2006 at 11:54 pmno question is silly I am finding out about this system.
I will check on the firmware update and when I install the new ram…will let everyone know the results
thanks again for your time
dave
Jeremy Garchow
October 21, 2006 at 12:19 amCool.
Firmware update:
https://www.apple.com/downloads/macosx/apple/macpromid2006efifirmwareupdate10.html
Jeremy
