Activity Forums Compression Techniques FFMPEG: I need to remove 14 out of 16 audio channels from a mov file
  • FFMPEG: I need to remove 14 out of 16 audio channels from a mov file
    Posted by Andreas Wojtaschek on September 3, 2019 at 8:05 am
    first of all: I’m new to FFMPEG so I need some help from some professional users.
    I have a relative simple task:
    I have some MOV files with a single audio track that contains 16 channels.
    I want to remove the last 14 tracks and create a file with copied video (no reencoding) and just the first two audio channels. The 14 last tracks should be discarded.
    I found a lot of tutorials for creating 5.1 files etc. but not what I need. Could someone please point me to the right direction or even post the command to accomplish this task?
    Thanks so much for all your help!
    Robert
    Lou Logan replied 6 years, 11 months ago 2 Members · 1 Reply
  • Lou Logan
    October 9, 2019 at 7:05 pm
    It is not possible to split channels or use filters without re-encoding, but in this case you can stream copy (re-mux) the video without re-encoding because you are not filtering it.
    Use the channelmap filter:
    ffmpeg -i input -af "channelmap=map=0|1:channel_layout=stereo" -c:v copy output
    or
    ffmpeg -i input -af "channelmap=map=FL|FR:channel_layout=stereo" -c:v copy output
    See “ffmpeg -layouts” for channel layout names and descriptions.
