Activity Forums Compression Techniques ffmpeg, create MPEG2 from series of GIFs
  • ffmpeg, create MPEG2 from series of GIFs
    Posted by Mark Aren on October 23, 2011 at 5:47 am
    Hi All,
    I have a series of 60 individual, static GIF images, each 720×576 pixels (actually moving hands on a small clock). I wish to encode this to MPEG2 video at 2920kb/s with a duration of 60 seconds (1 sec per GIF frame).
    Current command line is
    ffmpeg -i tc_%02d.gif -r 1 -y -an -vcodec mpeg2video -b 2920kb -r 25 -s 720×576 TC_ZL3JVX.mpg
    Error message is unable to find a suitable output format for TC_ZL3JVX.mpg
    The resulting MPG will eventually be muxed into a transport stream for transmission using Digital Amateur TV, but that is a few steps away.
    Any help or pointers appreciated.
    Mark
    Daniel Paluska replied 14 years, 9 months ago 2 Members · 1 Reply
  • Daniel Paluska
    November 23, 2011 at 8:18 pm
    have you tried stripping away portions of the command?
    starting here:
    ffmpeg -i tc_%02d.gif test.mpg
    and slowly adding terms until you get to here:
    maybe it’s a 2 step process.
    you could use imagemagick to convert the individual frames to jpgs? maybe it would be happier with that?
    or first make a movie without specifying the codec and then transcoding that movie to the final desired state?
