Activity Forums Panasonic Cameras Ferrite Core and Ipod question
  • Ferrite Core and Ipod question
    Posted by Lars Wikstrom on May 20, 2006 at 9:01 pm
    In the HVX200 manual page 78 it says to attach the provided Ferrite Core to the Firewire cable for doing transfers. What does the Ferrite Core do? Can’t I just connect a firewire cable like with my other camera?
    Also reading the manual, and please correct me if I am wrong. Can I connect a firewire drive right to the camera and transfer the footage from P2 to Hard Drive? I know you can record to a FireStore drive but can you use an off the shelf portable hard drive to dump to like my iPod? Not record to just transfer?
    -Lars
    Barry Green replied 20 years, 4 months ago 6 Members · 11 Replies
  • 11 Replies
  • Shane Ross
    May 20, 2006 at 9:09 pm
    [doka15] “Can I connect a firewire drive right to the camera and transfer the footage from P2 to Hard Drive?”
    Yes. You don’t need a computer to dump the footage onto a hard drive. There are menu settings in the camera that allow you to direct the camera to offload the footage.
    [doka15] “I know you can record to a FireStore drive but can you use an off the shelf portable hard drive to dump to like my iPod? Not record to just transfer?”
    Any drive will work, as long as it has a firewire connection and enough room.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Lars Wikstrom
    May 20, 2006 at 10:40 pm
    So I guess I could use an iPod then since it has it’s own internal battery. But the connection I have for it is 6 pin firewire and the camera is a 4 pin FW connection. has anyone used an ipod before to off load footage?
    -Lars
  • Uli Plank
    May 21, 2006 at 8:53 am
    Hi Lars,
    while I haven’t tried it with an iPod, the only difference between 4-pin and 6-pin FW connectors is the lack of power supply via the cable, the data will be there.
    A ferrite core is just an additional measure to make high-speed connnections more realiable, quite a few of the FW cables lying around in my studio had ferrite cores on them from the manufacturer. In many cases a cable without one will work as well.
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
  • Lars Wikstrom
    May 21, 2006 at 4:34 pm
    Thanks for the answer. Looking at it it seems to be a magnet of some kind. I wonder what it really does to the signal.
    Thanks.
    -Lars
  • Kerry Brown
    May 21, 2006 at 7:27 pm
    It’s not a magnet. Ferrite cores are used on cables to stop RF from interfering with the signals carried by the cable.
    The core and cable combination act as a filter.
    KB
  • Uli Plank
    May 21, 2006 at 8:03 pm
    For very high frequencies a simple cable is a very complex arrangement of capacitors and coils. This can cause reflections and subsequent enhancement or weakening of some parts of the signal. Think of the ferrite core as something like a sponge that cleans up undesirable ‘dirt’ signals.
    Hope this helps,
    Uli
  • Jan Crittenden livingston
    May 21, 2006 at 10:26 pm
    Nice explanation Uli, couldn’t have done better myself.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, DVCPRO, DVCPRO50, AG-DVX100
    Panasonic Broadcast & TV Systems
  • Lars Wikstrom
    May 21, 2006 at 10:46 pm
    That explains it. I have cable that have them already attached but this is the first time I have to attach my own. So I wasn;t sure what it did. Thanks for the detailed explination.
    -Lars
  • Kerry Brown
    May 22, 2006 at 12:03 am
    Uli, I disagree with part of your explanation: “For very high frequencies a simple cable is a very complex arrangement of capacitors and coils.” What you say about the charateristics of a cable is right on. The second part I have trouble with. “This can cause reflections and subsequent enhancement or weakening of some parts of the signal. Think of the ferrite core as something like a sponge that cleans up undesirable ‘dirt’ signals.” That is not the purpose of the ferrite core. They stop Radio Frequency (RF) noise and Electromagnetic Interference (EMI) from degrading the signal in cables. Long cables can act as an antenna (in effect). By changing the impedence (with a ferrite core) of the cable you suppress this interference. RF and EMI interference is not limited to tv/radio stations, but also household appliances, computers, cars, etc.
    Respectfully, Kerry
  • Uli Plank
    May 22, 2006 at 7:27 am
    Hi Kerry,
    of course you are giving the right explanation. I was trying to keep it simple. Technically speaking, the ferrite core is dampening the cable when it might act as a tuned circuit for certain frequencies, so it’s weakening it’s resonance for incoming signals and cable reflections alike.
    BTW, one of the worst sources of electromagnetic pollution these days are cell phones. I suppose everybody has already heard the typical sound of a nearby phone on their stereo or iPod headphone by now.
    Respectfully,
    Uli
