Activity › Forums › Panasonic Cameras › Ferrite Core and Ipod question
Barry Green
May 24, 2006 at 11:50 pm[Shane Ross] “Any drive will work, as long as it has a firewire connection and enough room.”
While this is true, there’s another little tidbit one would want to keep in mind: do NOT use a drive that’s being used for any other purpose, because the HVX will format it and delete everything that’s on that drive!
Only use a drive that you can dedicate solely to offloading from the HVX.
If you choose to use your ipod for offloading, understand that the HVX will format its drive, and your ipod will no longer function as an ipod.
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
