Activity Forums DaVinci Resolve feature request: Hue and Sat curves
  • feature request: Hue and Sat curves
    Posted by Blase Theodore on November 21, 2010 at 8:17 pm
    Coming from Quantel IQ and Apple Color, the ability to adjust color hue and saturation via a curve tool was essential. Sometimes its simply the only tool for the job. Unfortunately not having it is more than just an inconvenience of having to use another tool. Some shots simply can’t be corrected without it.
    I have tried to mimic the tool by using a hue-only qualifier and softening the hue selection out (hue softness, not selection blur) but the results are dirty and noisy compared with the same shot “hue-notched” in Color.
    I understand this is probably low on the priority list compared to fixing features that are already almost working, but please consider this for your long term list.
    Thanks for reading,
    Blase
    Blase Theodore replied 15 years, 9 months ago 18 Members · 46 Replies
  • 46 Replies
  • Ola Haldor voll
    November 21, 2010 at 9:37 pm
    It’s interesting – I’ve see this kind of request pop up a few times now.. I never touched these controls in Color, so I’m not missing them.
    Any explenation on the purpose of them and why you’d do the job with those controls vs. those in DaVinci at the moment would be an interesting read..
  • Blase Theodore
    November 21, 2010 at 10:28 pm
    Example scenario
    Lets say you have an image that was balanced for daylight and then exposed to tungsten. Super yellow. If you shot it on say 5D, there’s not gonna be much info to play with…
    In resolve:
    You’d “balance the image” by pulling out yellow and adding blue till it looked neutral. At this point you’ve thrown away half of your image data (lets assume 411 colorspace for simplicity- The blue channel contains 1/4th of the pixel data of that green channel, and the image itself has very little blue in it. You’re throwing away the yellow green which is the strongest channel, and stretching out the blue which is the weakest) So your image starts to look like crap.
    Or..
    You use the qualifier to select yellow hue only, and you desat and hue shift it before grading a second layer. The result is dirty. Don’t know why but I’ve compared it.
    In Color:
    You’d open a secondary curve, notch the yellow and green sat down, blue magenta sat up. Then you’d nudge the oranges towards red, and the blues away from magenta. You’re not throwing away pixel data, you’re just reshaping it.
    When an image is exposed too warm or too cold, the colors exhibit a non-linear hue shift. The reds might be in the right spot, and everything else may need to shift exponentially.
    Also curves are super fast. I can make trees the right color green, or fix skintones, or fix a sky in a matter of seconds. Waaay faster than pulling a qualifier that doesn’t suck, and definitely cleaner to paste across many shots.
    Lastly as a styling tool, they’re much faster to get a certain look.
    If I wanted to get the “steely action” look, I’d desat the yellows and reds, and nudge the greens hue up towards blue, and the magenta hue down towards blue. reproducing such a style with qualifiers would be time consuming and possibly difficult across multiple shots.
  • Robin Erard
    November 22, 2010 at 8:10 am
    Hello,
    I’m agree, curves are so usefull. It is the first thing I use to correct a “skin tone”. Or to desaturate a color range.
    I hope they will add this in the next version
    Robin
    réalisateur, scénariste, monteur
    http://www.robinerard.ch
  • Ronald Anderson
    November 22, 2010 at 10:46 am
    I am presently working with David Cat of Film Systems, here in Alpharetta, GA. Together we are putting forward suggestions, and recommedations for software updates and improvements to Black Magic. I am showing David the simplicity and ease of the secondary graphical displays in Apple Color, so as to add a similar tool set in Davinci. I agree with your posting, that they are a very quick way to achieve hue and saturation adjustments, without having to make a “qualifier” and fine tune it.
    On another note, I believe that working in Drop Frame time code is coming very soon…..
  • Erik Lindahl
    November 22, 2010 at 10:54 am
    Even if I’m not a DaVinci-user yet, I do use Apple Color extensively and this is one of the single most used features I love for color-correcting or grading in there.
    – Tweak saturation in all colors or get more of a selective-color look with 1 secondary
    – Tweak hue in all colors with 1 secondary (the same secondary if you want to).
    It’s awesome for so many things I don’t even know where to start. I would have thought this was a “standard” grading features but evidently it’s not.
    Erik Lindahl
    Freecloud Post Production Services
    http://www.freecloud.se
  • Robbie Carman
    November 22, 2010 at 2:44 pm
    [Ronald Anderson] “Drop Frame time code is coming very soon”
    Yes that is that is what I’ve been hearing. Hooray!
    Robbie Carman
    Colorist and Author
    Check out my new Books:
    Video Made on a Mac
    Apple Pro Training Series DVDSP
    From Still To Motion
    Twitter
    Blog
  • Joseph Owens
    November 22, 2010 at 3:50 pm
    Eh?
    Er… six-vector hue/sat secondary control was standard from the very first Renaissance. ????
    So…. the more “sophisticated” the tool gets, the more simple, direct methods get dropped?
    Am I missing something here? This sounds ridiculous.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Peace Villow
    November 22, 2010 at 5:41 pm
    [Joseph Owens] “Eh?
    Am I missing something here? This sounds ridiculous.”
    The last time I used it (yesterday) the six vectors still there.
    Although now instead of using individual knob for each color (like in the old 2K panel), you only have three HSL knobs for all the colors.
    So you have to select the color first (there’s a preset for this on the Resolve panel so you don’t need to pick a color from the image) then change the HSL using the three knobs.
    Now the problem is: the six-vectors color preset (RYGCBM) only appears when you use the Resolve panel.
    If I’m not wrong, you can’t load the six-vectors preset using the Wave panel or mouse&keyboard via the GUI.
    The real question is: Does the six-vectors in Resolve do the same thing as the Hue_Sat curve in Color? 🙂
    I have no access to Color, so maybe someone can check this for us.
    Best,
    Peace Villow
  • Vladimir Kucherov
    November 22, 2010 at 6:22 pm
    Aha, another resolve panel only feature. I’d be curious to see what the full list of those is.
  • Ola Haldor voll
    November 22, 2010 at 8:59 pm
    Having a complete list of Resolve panel only features would possibly make more sense to value the panel as more than just a tool with rings, balls and buttons as I would think it was.
Page 1 of 5
