Activity Forums Apple Final Cut Pro Legacy FCS3 to Avid gamma shift – need help!!
  • FCS3 to Avid gamma shift – need help!!
    Posted by Nikolai Vavilov on March 3, 2010 at 12:44 am
    I have a HD project shot with Red One camera, graded with Da Vinci using pro-HD CRT monitor, exported to ProRes 4:2:2 HQ. It looks wonderful back in FCS3, but I need to export to AVID aaf format (SD-PAL). I have AutomaticDuck ProExport plugin, and Avid MediaComposer mac version installed.
    Tried different ways: export with AutomaticDuck, exporting to SD-quicktime with different settings (8-bit uncompressed, DV-PAL, etc, etc…) and importing to Avid MC, – all ways ends with same result: picture looks way darker and contrast in Avid…
    Please help! Need to find right way to export ProRes to Avid aaf SD without gamma issues
    upd: OSX 10.6
    Stefan Engelkamp replied 16 years, 6 months ago 4 Members · 4 Replies
  • Michael Gissing
    March 3, 2010 at 12:51 am
    Did you try 10 bit uncompressed? ProRes is a 10 bit file.
    Also are you judging the gamma on both FCP & AVID on an external monitor?
  • John Pale
    March 3, 2010 at 1:14 am
    Avid has a setting in the import settings for RGB or 601/709 material. Which ever way it’s set, try the opposite and see if it helps.
    Be aware that some versions of Avid had a bug with this setting where it did not
    work properly in all resolutions. You could be encountering that.
  • Nikolai Vavilov
    March 3, 2010 at 1:20 am
    Thank you, will try to find another version of Avid to try this.
  • Stefan Engelkamp
    March 9, 2010 at 11:20 am
    We have the same problem here with our Automatic Duck exports from FCP PRORES HQ to DNX185HD. There is a hefty gamma shift when exporting to a MAC based AVID.
    Funny enough – it works fine when exporting to a PC AVID.
    Looks like the old 1.6 vs. 2.2 problem.
