Activity Forums Apple Final Cut Pro Legacy FCS3 retrograde to FCS2 troubles
  • FCS3 retrograde to FCS2 troubles
    Posted by Pat Mcgowan on March 20, 2010 at 6:29 pm
    We are attempting a retrograde from FCS3 to FCS2 and cannot get the install to complete.
    Have tried FCS Remover to no avail.
    Anyone have a bulletproof method for this?
    Pat Mcgowan replied 16 years, 5 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    March 20, 2010 at 6:55 pm
    [Pat McGowan] “Anyone have a bulletproof method for this?”
    My “bulletproof” method is to clone my system drive before I install the upgrade, then if I need to revert back, I can simply boot from the backup. If necessary, I can format my system drive & clone the backup back to that.
    If you’re really in need of going backwards, you may need to reformat your drive & reinstall from the ground up.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Robb Harriss
    March 20, 2010 at 8:11 pm
    did you try CleanApp to pull off the old installation? As well as FCS remover.
    Non-linear: all the time and nothing but.
  • Pat Mcgowan
    March 21, 2010 at 7:59 pm
    tried FCS remover, no go, ended up using Carbon Copy Cloner to clone a different sys drive and then simply applied the new SER#, worksed like a charm.
