Activity › Forums › Apple Final Cut Pro Legacy › FCS2 – playback speed has dropped :-/
  • FCS2 – playback speed has dropped :-/
    Posted by Simon Blackledge on June 4, 2007 at 7:06 am
    Anyone else having playback speed from disk errors from projects that used to play fine?
    Or disk speed errors/ framedrops on capture on a system that previously worked fine?
    Our raid no longer seems to be able to capture more than 3 mins of 720P60 8/10bit but previously would happily capture 30mins+ :-/
    plus fcp6 says disks to slow with one clips above another with animated transparency in a seq where prior to fcp6 Blackmagic update I had 3 streams with animated transparecy play fine from our raid…
    anyone??
    cheers
    P
    Simon Blackledge replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
