Activity Forums Apple Final Cut Pro Legacy FCS 3 upgrade from 2 on Lion or drivers for snow leopard on new iMac i7
  • FCS 3 upgrade from 2 on Lion or drivers for snow leopard on new iMac i7
    Posted by Brian Cooney on November 21, 2011 at 11:23 pm
    purchased a new iMac quad with i7 proc. Firmware is different so I can’t install my Final Cut Studio 2 software and then subsequent FCS3 upgrade. I would be happy to install Snow Leopard but tried that and evidently I don’t have the drivers. Does anyone have any work arounds for this? Tried partitioning. that won’t work. Tried migrating from another computer. Does a Snow Leopard disc image with modified drivers exist out there? – Brian
    MotionFoundry, Inc. Video Post
    Clients: GM, AOL, Kohl’s, 3 Doors Down, Thomas Nelson, NASCAR Affiliates
    Neil Patience replied 14 years, 6 months ago 3 Members · 4 Replies
  • Neil Patience
    November 21, 2011 at 11:32 pm
    Why do you need to install the FCP Studio 2 version at all? You should be able to use the ugrade FCP Studio 3 version, which will install on Lion, it will first ask you for the FCP 3 serial number, then it will say thats an upgrade enter the serial from the product you are upgrading from.
    Type in your original FCP 2 serial and away you go.
    best wishes
    Neil
    http://www.patience.tv
  • Brian Cooney
    November 21, 2011 at 11:53 pm
    wow I feel dumb. I wasn’t aware that the Upgrade DVDs contained all the information in a full install. is this true? thanks
  • Shane Ross
    November 22, 2011 at 12:04 am
    Upgrade installs are the FULL install. The only difference is the serial number…it requires a previous full version number in order to install.
    Don’t install previous versions then the upgrade. Just install the latest…have that FCS2 serial number handy.
    Shane
    Little Frog Post
  • Neil Patience
    Yep its true – have done it many times including 2 Lion installs, clean installs are better in any case.
    You just need both serials handy.
    best wishes
    Neil
