Activity › Forums › Apple Final Cut Pro Legacy › FCS 2 main install disc not showing up…
  • FCS 2 main install disc not showing up…
    Posted by Tad Newberry on July 18, 2007 at 8:02 am
    i put it in after wiping the system drive (backed it up to FW drive), and it doesn’t launch, and doesn’t show up anywhere. so i installed Studio 1, thinking this main disc had to see an earlier version, but no dice.
    the other studio 2 discs do open up, but just not the main one.
    wut up wif dat?
    thanks for helping out a bonehead!
    __________________________
    dual 2 GHz PowerPC Mac G5
    2GB MB DDR SDRAM
    GeForce FX 5200 graphics card
    Tad Newberry replied 19 years, 2 months ago 1 Member · 3 Replies
  • Tad Newberry
    July 18, 2007 at 8:34 am
    alrighty, well, after sitting in the drive for about 20 minutes (and being very quiet), the install window opened up and i started to “Install FCS”. then the Installer application “suddenly quit”, so i started over…same thing…restarted, and it’s off and running like a normal install.
    makes me feel a little “iffy” about this install. have any of you experienced this?
    2GB MB DDR SDRAM
  • Tad Newberry
    July 18, 2007 at 3:25 pm
    the LiveType Media 2 disc was not being read either. after about 10 tries (plus letting it sit there all night to see if it might happen), i finally just went on to the Motion Content disc and that one is installing fine. . .
    i’m guessing i could probably install the LiveType Media 2 disc later if needed, without screwing up too much inside of Studio 2???
    2GB MB DDR SDRAM
  • Tad Newberry
    July 18, 2007 at 4:29 pm
    so i inserted the last few discs, which opened fine (though via a new finder window and not from the “Installer” requester), but they all installed fine. then i went back to LiveType Media 2…and it opened in a Finder window. it installed fine, but now i have this frozen Installer window still asking for LiveType Media 2 that won’t close and won’t go away….
    i hate to do a Force Quit, or worse yet a hard reboot, as it seems it could corrupt the install…but what else can i do right now? i can’t get back to the “finish” part of the install menu because that frozen window is still asking for LiveType Media 2 (even though it has now been installed, though just not via Installer).
    maybe i have gremlins in my house???
    2GB MB DDR SDRAM
