Activity › Forums › DaVinci Resolve › FCPX XML to DaVinci 10 – Difficulty with remote clip (through edit) recognition
  • FCPX XML to DaVinci 10 – Difficulty with remote clip (through edit) recognition
    Posted by Sascha Engel on October 27, 2014 at 4:11 pm
    I exported an XML from a 3 Cam Multi Cam edit (FCPX 10.0.9).
    After I imported the XMLto DaVinci 10. All the edits came in fine, no problems.
    But all the edits refer to 3 Cameras (1 Total and 2 CUs).
    Unfortunately, it does not give me the red little symbol that indicates the through edit connection to the Masterclip.
    Any idea why and how it’s possible to “remind” DaVinci to the link?
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
    Sascha Engel replied 11 years, 11 months ago 4 Members · 6 Replies
  • Joseph Owens
    October 27, 2014 at 6:19 pm
    [Sascha Engel] “Any idea why”
    First guess would be that the multicamera sequence is being handled in a similar fashion to the import strategy that would be applied to either a completed export movie that would be marked out with either SceneDetect or an EDL. Even though the master is a single clip, the way the events are represented in the Resolve timeline are as independent clips. There is no way of “joining through” any of the clips in a SceneDetect import, either.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Sascha Engel
    October 27, 2014 at 8:36 pm
    Yes, but the weird thing is, that I had the automatic import Media to Media Pool box checked and it did import only the 3 entire takes, it did not chop it up in bits and pieces, so why does it not see them as whole clips then?
  • Eric Johnson
    October 27, 2014 at 8:51 pm
    Is your timeline in “remote” or “local” mode?
    eric b johnson
    online editor | colorist | workflow
    https://vimeo.com/ebjohnson/colorreel
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Sascha Engel
    October 27, 2014 at 8:56 pm
    I was sure in remote mode, but now I start doubting it….will check it tomorrow in the studio first thing!
    Sascha Engel
  • Juan Salvo
    October 27, 2014 at 9:25 pm
    I think what you need to do is uncheck us local grades and check the match media pool to master timeline options, before import and conform. Also make sure your clips aren’t being treated as subclips or compound clips.
    https://JuanSalvo.com
    https://theColourSpace.com
  • Sascha Engel
    October 31, 2014 at 1:53 pm
    Thanx, that was the problem, unlike 9, DaVinci 10 is auto set to Local Version. Thanx!
    Sascha Engel
